create xml-notification target url
create xml-notification target new-target url url {vr vr_name} {user [none | user]} {encrypted-auth encrypted-auth} {queue-size queue-size}
Description
Creates the Web server target in the XML client.
Syntax Description
new-targetSpecifies a name for the target being created.
urlSpecifies the Web server URL.
vr_nameSpecifies the name of the virtual router over which the XML client process can connect to the Web server.
userSpecifies the name of the user.
encrypted-authSpecifies the encrypted user authentication string.
queue-sizeSpecifies, in numeric format, the size of the buffer that stores incoming events from ExtremeXOS.
Default
N/A.
Usage Guidelines
Use this command to create the Web server target in the XML client process.
You cannot enter a password in the CLI directly. It is a two-step process similar to creating a user account in ExtremeXOS.
The following command creates a target target2 on http://10.255.129.22:8080/xos/webservice with a queue size of 100:
create xml-notification target target2 url http://10.255.129.22:8080/xos/webservice queue-size 100
This command was first available in ExtremeXOS 12.4.
The virtual router option was added in ExtremeXOS 12.4.2.
Platform Availability
